Originally Posted by
tcharger
You say you changed the venturi after break in, have you changed the glow plug, or are you still running the one you broke in with? If you are replace it with a fresh one.
Multi-quote does not work for me (I didn't manage to make it work...) so I'll answer each message individually.
Yes, using the same #8; now the engine runs fine.
