I was actually planning to bring up the shaft starting option, the 21r equipped associated mgt came with the dual start system for pull or shaft starting. I was going to ask which starter you preferred, pull, roto, or combo pull/shaft. I planned on keeping the aftermarket cooling heads, letting you choose the red(stock mgt) or purple(stock Schumacher Menace- this one is shaped like the original mirage cooling head)
wing shouldn't be a problem, but radio box cover I won't have. Although I have a few complete radio boxes and one might fit. Same with fuel tank, I'll have to get a look at the original to see which one of these will fit best on the chassis.
