Old 08-19-2018, 11:51 AM
FUTABA-RC
FUTABA-RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah, I understand now. This is an electric powered plane, correct?? If so you are using the BEC off the ESC correct? If so then it does not matter what size main power battery you are using since the BEC circuitry in the ESC regulates the voltage down to an acceptable level for the RX. I originally thought you want to use a 14.8 volt battery connected directly to the RX.
And again, Futaba is fully in business with plenty of stock. But if you want to use your 72 MHz stuff that will work fine if you are using the BEC through the ESC.
FUTABA-RC is offline
