last night a friend called and ask me to fly with him this morning, which I did, and I am grateful for that, the weather was very nice. He flew for 10minutes x 4 and I did 2x10 minutes flight and had to stop since the covering trim got pulled off.
The MSXR is mine, had I been patient enough to wait for the shorter stud, the extra holes at the front of the cowl could have been prevented
The twin RCGF 40cc is super fun to run on the plane.
The other plane is SLICK with DLE 30.
got home after work, I installed some silicone tubing on the H and L needle to help my screw driver stick on it while tuning, which took building time away.
I only managed to install the wing tube sock reinforcement on the fuse, as well as the rear main gear mount. I had to cut new mount since the first cut was 6mm shorter !
Its a bit soft and springy right now, I might have to reinforce it with some spruce stick.
