Can someone please tell me what temps are you are seeing with a cowling on? I've run the engine in without a cowl but I need to install it now and I would like to see what you guys are getting. I'm sure I'll have to baffle it but I'm not worried about that. Also how are you all reading temperature? I have a temp gun but with the cowl the access is limited, do you run it at wot then kill it and check? I'd imagine that trying to get a temp through a spinning prop would cause an error in the gun. Thanks in advance for the help.
