Originally Posted by
H201B
It occurs to me that rebuilding the stab saddle on this glider might be more work than it's worth. You could alternately shim the wing T.E. until the model glides properly at the correct CG. You will likely have to adjust the down thrust to get an acceptable climb rate. The Vista under power climbs like a rocket so you have some latitude there. My Vista flew fine out of the box.
Thanks H2O1B. Yep, I think that is the problem too. I tried everything...verified the CG, dive test and the only thing that seemed to work is a TE shim. But, I could hear flutter with the shim so I quickly landed. Might have been because the shim was a ‘field expedient’ thing rather than glued. This plane had some quality control issues from the manufacturer. Three pushrod tubes were glued in the fuselage rather than two. I had quite a time removing the extra tube that flopped around back there. Also the rudder pushrod exit was misaligned. The pushrod was severely binding. This is my first glider and I sure wish I had noticed the stab was misaligned. Thanks for your posts.
John
