Making Turbine Rails
Turbine rails were cut and dry fit. They had to be aligned with the hole in the rear of the fuse and level with each other. An aluminum bar was used to align with the rear hole. Some adjustments were needed in the slots to get both to line up.
Rails dry fit ready for alignement
Aluminum bar centered on rear hole
Wood clamped across stab formers to align bar with rear hole
1/8" ply doublers epoxied to turbine rails
Turbine rails complete ready for drilling turbine and pipe mounting holes
