Two things I'm going to say for this thread, one as a participant and the other as a moderator:
1. Sweep doesn't matter when setting incidence. The designer of the plane has specified an incidence that both wings need. If this is your own design or you are tweaking a plane to change the performance, each wing's incidence setting will affect the plane's flight. There is no rule that the top wing needs to be at zero or 1 or any other number.
2. Niceness gets you more help and makes you more friends than rudeness. Some people just really like to post pictures. Let it go.
