If Matrix did the gear,then I would give them a try first. If they don't work as intended,you just have to fit one of
these inside the wing or nose, and find a way to connect the end ball fitting to the landing gear shaft. They have a LOT of torque on a very small package.
I will try to sketch something for you regarding the flexplates,specially the nose.
David
