Juan,
I cannot get into the start parameter's menu.. All's I can see in there is Glow Voltage, ECU Voltage and Fuel P/W #... Only these 3 values. I cannot adjust the " Auto + #. or any of the other Items that I am used to seeing.... Is it locked ? If so will the old codes work for the earlier Xicoy ECU's that had the small ECU's and external valves like my other Rhino # 183 ???
My issue is that it is staying in " Switchover " for a long time and staying around 10,000 to 11,000 RPM and then it finally catches and goes to " Fuel Ramping " and goes on up and starts from there... I need to get it to get through switch-over faster. I mentioned this to Manny before he left for JetPower and he was going to mention it to you... Please tell me what to do .
I also shipped my Cheetah SP ( #3228 ) to you today it is having starting/flame-out problems... Be on the look-out for that one coming in..
Talk to ya soon !!!
Cheers,
Dan Massey
