Originally Posted by
TimD.
OK., I just got around to finishing mine up this week. Where did you guys figure your CG at. The online manual states 175mm back from intake lip . That is way off according to my calculations of the wing/fuse planform. I came in at 11 1/2"" - 285mm back. OR 4 "- 100mm in front of the rear spar / 1" - 25mm in front of the mains.
I will probably move it forward a bit more to be cautious for the first flight.
The instruction book calls for 175mm back from the wing indentation (and handy-dandy panel line) - NOT the lip. Several other threads exist, and Bob Klenke had his at 185mm when we talked. I maidened at 185 and am moving it back (due to the amount of up elevator needed) as did he. I will try to pull the plane down tomorrow night (have a meeting until late tonight) and look at where you have it measured vs where I am now.
Greg
