Originally Posted by
Antares100
Hi, Brendon. Thanks for the response, but not sure what you mean by "30 degrees in front of CG. Rest". Do you mean approximately 1/3 the distance between the CG and main spar?
No, first determine where your CG is and then place the tow hook 30 degrees in front of that, in other words, say your CG was on your main spar then your tow hook would be placed 30 degrees in front of the main spar.
