Still not feeling myself, but eventually got some more of the build done. Did some shaping on the rudder blocks & base, fitted the two strips to laminate the rudder trailing edge. Then decided to look for the block of balsa for the rudder tip. An hour later, after emptying the box using my enigma machine to try to decipher the TF code for the piece, I decided to look in the box lid where I'd stored the U/C, ABS parts & the empty sheets of die cut parts. there it was in a plastic bag of other yet to be discovered parts. I placed it over the plan & drew in the approximate shape & centre lines, then partially shaped it. To go by the manual, the rudder has to be clamped to the fin for final shaping, so I glued the tip to the rudder to leave overnight until it's set to do the final shaping. That's it for the 1st of October, Incidentally, the image count has now passed the 150 mark & the back end still isn't complete.
