Hope this help
339说明书
Mb339 instruction
整机复材生产
Overall composite material manufacturing.
翼展:175cm
Wingspan:175cm
机长:185cm
Length:185cm
建议最大舵量
Rudder amount
副翼:15mm
Aileron:15mm
升降:20mm
Elevator:20mm
方向:25mm
Rudder:25mm
襟翼:一级15度,二级45度
Flaps:1st 15 deg 2st 45 deg
主油箱容量:2270cc
Fuel tank capacity:2270cc
接收机不低于12通道
The receiver is not less than 12 channels.
舵机:襟翼20kg标准舵机*2,其余中型舵机*8
Serov:flaps Standard server*2 other mini server*7
发动机:8kg
Engine:8kg
建议电池容量:2s2200-2600
Recommended battery capacity:2s2200-2600
重心在机翼根部前缘往后13.5cm,对应图中翼尖前缘位置
