With the new engine did all the other items get changed as well? Fuel Pump?
or did new engine get installed with previous equipment?
Originally Posted by
smiller
Well when the second engine did the same thing I thought the same way, must be issue in my airframe. My friend has a plane with an older Cheetah , we put my engine in his plane using his power harness and batteries also a different communication harness and it did the same exact thing {quits when power pulled back to 1/4 or below} This only happens in flight, runs fine on the ground . Two engines doing the same thing, one tryed in a different airframe with the same results. Strange !
Scott
