Originally Posted by
CARS II
I have always set mine to completely close the throttle killing the engine on my turbines when activated ( never had one happen yet ) reading the rules once again ( 510-a, 9. All radios must be equipped with fail safe and ECUs shall be configured to shut down the engine
within 2 seconds of fail safe activation ) I understand that I can set the radio fail safe to idle and if it goes to fail safe passed 2 sec then the ECU will shutdown the engine.
Yes? No?
Tks.
You can keep doing it the same way if you want. If you set failsafe to instant shutdown by closing the throttle, ECU will think/act just like you shut it down in the pits.
The rule for 2 second delay was added if you felt you needed it......in case you got a quick failsafe and did not want the motor to shut down
