Originally Posted by
Gar35
i have a saito 82. How much more power does a saito 91 have than the 82? I’m looking at a 90 size plane with a 75” wing and only weighs eight pounds.
Gar, keep in mind that in the 2 test's Dave posted the 82 was tested with APC props and the 91 was tested with Zinger props,
also, the Saito 91 is a well powered engine, but not made any more, you can still buy them pre-owned NIB for good prices,,
but you did not say what plane or what type of flying, so keep in mind that the Saito 100 is a light engine, it weighs
only 2 more grams than the OS AX65 2 Stroke and 42 grams less than the OS 95V 4 Stroke, and is a bit more powerful than the Saito 91,,,
Good Luck
Jim
if you own a Saito engine, you should buy another
