RCU Forums - View Single Post - Electriflying Top Flite Stinson Reliant
Old 10-09-2018, 07:58 AM
  #57
stearman65
stearman65's Avatar
Default Frustrating couple of days
Really having trouble interpreting the plans & manual. Having to blow up the PDF file on the PC, move to the workshop then back to the PC. Eventually brought the multi component ribs to the PC to help indentifying which was which. Doing so I identified one puzzle relating to the outer trailing edge spar. on page 17 top right it says "Cut along the partially die-cut line of one die cut 1/8" balsa outer TE spars and remove the jig. Glue that outer TE spar to the front of another outer TE spar that has the jig still attached. which to me was double dutch, (no insult intended to our Dutch friends,) After laminating the two pieces of TE spar & setting them aside for a couple of days, I was puzzling over the multi piece ribs on the PDF & found the partial die cut which just about scores the balsa on the actual piece, still not sure how to proceed, at least I haven't cut off something I shouldn't have.
