Hey Gary I have a similar task to do on a nose cone, the tubes and magnets. How are you planning to line up the tubes so they are all parallel with each other? Any slick trick?
EDIT my idea was to glue the pins (or receptacles, does not matter which) on the nose cone side first.
On the inside of the cone, have some scrap rectangular (matched) stock hold the pins in place and parallel with each other while the glue dries. Then of course the nose cone jigs in the recepticles on the fuse side.
This sounds exhausting.......
