Thought I had the remaining bits and pieces to finish building, but I'm waiting on some cable pushrod for the nose wheel and throttle.Little bits and pieces behind the CG are slowly working out the balance with the servos almost all the way back and the battery just in front of the servos. For a little while, I was thinking something looked different on this plane and then it hit me, it's not much, but the nose is about 3/8" longer. On my first Komander, I recessed the mount into the firewall to cram the 4 stroke in there. This time, I mounted the motor to the firewall normally and built the cowl out a bit further to make up the difference. Weather is supposed to be crappy until next weekend, so still a chance for a maiden before the snow comes.
