With some of the newer turbines having the fuel pump in the turbine, the optimum fuel line configuration is different. The P-140 has the pump in the turbine and would not spool up to full power w/o high-flow fittings, UAT, clunks and lines. I also went with larger tubing in the tank's stopper. Kind of makes sense seeing how they put a 6mm fitting on the turbine. The hi-flow setup not only allowed full power, but I also added a huge hopper tank in the fuse. The typical hi-flow BVM type UAT's outlet is 8 mm versus the normal UAT''s 6 mm outlet. I used 3/16" tygon to the UAT and 8 mm line out of the UAT. I converted down to 6 mm just before the turbine. These several changes solved the spool up problem and short 6 minute flights. I have the Ultra Flashes' main, two saddles and a large hopper for tanks.
The K-160 has an external pump that makes a conversion from 6mm to 4mm at the pump. So the inlet side was set up with 6 mm lines, hi-flow clunk, larger tubing in the fuel tank stopper, normal UAT, 6 mm fittings to the pump. Then it is 4mm from the pump to the filter to the turbine. I used the T-One's smoke tank in series with the main tank for added fuel. I now can get 10 + minutes flights on the K-160. The hi-flow clunk was only used because that is what I had laying around.
Point being, if the pump is internal, the fuel system setup may need to be different. Also, the smallest passageway in the fuel system is the biggest constraint. Add a second constraint and the effect is even larger. There is a flow differential at every constraint. And lastly, for fluids it is harder to suck/draw than it is to push fluid out the outlet. The harder the system draws fluid, the more likely that future air in-leakage may occur. We are stuck having to draw fuel to the pump thru our tanks. At some point, the restrictions in the inlet side may limit fuel flow as I experienced with the Ultra Flash. So why not minimize the effort it takes to get fuel to the pump?
