https://www.nitrorcx.com/99b-10021-650-ep-artr.html
This is the new Exceed Racing 23 in. Fiberglass Electric RC Boat. Highly detailed features make this boat one of a kind. This RC boat comes with a high performance racing 3300kv Brushless motor and a 80A Brushless ESC for super fast speeds and great maneuvering capabilities. Measuring over 23 inches long and featuring a professional large torsion propeller, water-cooled engine, and this RC boat is perfect for ponds, rivers, and lakes. Take this fully functional reproduction of an offshore boat out to the water and watch it cruise! This RC boat is ARTR (Almost Ready-to-Run) you need a receiver, and a transmitter to get it out cruising on the water.
Length: 600mm (23.62 inches)
Beam: 165mm (6.49 inches)
Height: 80mm (3.14 inches)
Weight: 1150g (40.56 oz)
Hull Type: Fiberglass Mono 1 Step Bottom
Propeller: Carbon-reinforced plastic D36*P1.4 3-blade
Driveline: Solid with Flexible Joint Drive
Hardware: CNC Aluminum Strut and Rudders
ESC: 80A
Radio (Required): 2 channel
Motor: 3300KV water-cooled brushless
Weight Added (Required): 60g Pb for Auto Stable
Battery (Required): 7.4v 4500-5400mAh LiPo
NOTE: The lead weight doesn't come with the boat.
