Originally Posted by
DUCMOZ
Hi MS200a
Thanks for all the details. From what you see, do you think the gear / gear mounts would hold up on a semi rough grass field ?
thank you.
Yes the gear and mounts are quite robust, and trailing link is a good choice for bumps. FYI both pinch bolts on both of the mains loosened, so I would lock-tite them. The pinch bolt is a star bit and the head will not clear the gear frame, but you can back it out a bit put a drop in the hole and let it creep in, then a drop on the other side and tighten it back up. since i did that they have stayed snug. Also the ventricle fins and wing tanks screws will loosen lock-tite those as well
