Originally Posted by
dubd
I’m going with the new electric retracts from CARF, which I believe are about the same price as the pneumatic gear. Do you think the price of the gear for this plane is comparable for gear from other high end kits? i.e. Tomahawk and Airworld?
Dantley - I'm going with the CARF electric set as well. If it's painted as the pictures I've seen with the nicer wheels and brakes it should be very good. I'm looking in to whether I use servos or actuators for the gear doors so I can pretty much remove the air system all together. Andreas says servos apparently but would be interesting to know if anyone has found actuators that work for the job?
