My question would be why the want/need for a smaller prop than what is reasonable .... I totally agree with the above posts . A small prop on the DLE 35 will only achieve premature failure from over reving the engine. Anything above 9000 rpms sustained will ensure a short engine life. A 16x10 three blade would be the absolute minimum prop I would use and even then you need very good throttle management.
