Jetflyr.................wow thanks your picture is exactly like the way I have my tanks set up as well. Is your tanks 16oz each? If so, should be the same amnt of weight.....Just to confirm, you balanced at 185mm WITHOUT FUEL. I have my tanks set up on a tee. The two saddle tanks should be used at same time before the main tank is used. Do you think this is ok? Just for info, do you remember how much weight you had to put in the nose for balance?
tks
