after maiden flight with the 100n engine you may want to detune it in the ecu with high rpm limited lower than full. this will make your throttle easier to control it is hard to fly a turbine at 85% and repeat that setting on the sticks
piggy back tanks are always better if you can do it and the bottom one drains last..
