Began installing servos in servo wells. There are 5, all done the same way.
1/16" G10 servo well covers all cut, drilled, and countersunk.
Servos mounted to brackets, servo arms attached, and brackets mounted to G10 covers.
Parts of plywood mounts and airex material on inside of top skin removed as necessary to get clearance for servo and bracket.
Once the servo cover was dropped in servo the well it was not flush with skin surface so it had to be shimmed on each corner.
After proper shim level achieved, shims were glued in, holes marked, drilled, blind nuts installed, edges sanded, and 4-40 flat head bolts installed. Right aileron servo completed.
Right flap servo completed
RIght wing done, left wing to go.
Low angle view.
