Little update, wooden kit of "Mirce models" F 104 Starfighter is still available and news is that we offer now 3D printing tip tank.
Dimensions of 3D print tip tank:
- 1359 mm long
- 130 mm in diameter
- with all inner ply rings & parts, aluminum screw guide tubes - weight is just 656 gr!!!
We suggest to cover tip tank (no fins) with 40 gr/sq meter glass cloth and epoxy resin.
Then filler, primer, sanding...
That will give very big strength and super smooth surface...
Set of 3D print F 104 tip tanks is available and can be ordered.
