Originally Posted by
sideoftheroad
I’m building a George Harris Draco and using a At6400t brick which was also used in the spectrum mosquito.
I have both ailerons going the same way (both going up and down at the same time) and can’t figure out how to get one aileron to go in the opposite direction.
I’ve tried reversing aileron using the transmitter and also tried the programming provided in the manual.
suggestions?
If you are using two servos for your ailerons, you will probably need a reversing cable for one of them.
