Originally Posted by
ForcesR
What degree crank offset did you order with the IL135, 270 degree or 180 degree? The 270 degree offset will produce the warbird scream while the 180 degree will give a fairly even sound.
Thanks Tom.
It's the 270.
Iv'e been adjusting the high from 1.5 to .5 turns out and it doesn't seem to make much difference.
The low side is perfect.
Running a Fiala 30x14 with 4700 on the ground.
This is as good as i can get it.
Cheers
Rob
