Originally Posted by
marksp
Assuming Mercury setup same as Royal, I’m using (2) Jeti Duplex EX R3 REX receivers connected to Rx1 & Rx2 ports, with one also connected to ‘TELE’ port for telemetry. I decided using (2) 2.4GHz was better that (1) 2.4GHz and (1) 900MHz.
Cheers
I've got two R3/RSW receivers connected to a PB Mecury SRS, I can see the telemetry data from both the receivers and the Mercury, but I cannot get any servos to respond? I tried changing the Servo Inputs on the Mecury but still no luck, any ideas? Thanks for the help, Tom
