Not a big problem but still an issue . Last night while assembling the outer panels to the center, the wire wouldn't meet up .The way the wire lead strings are laid in the center section and outer panels doesn't work out . The wires pull through well enough but don't come out in the same location on the center and outer panels . Looks like I will have to make some changes to the plane . The servo wires run in front of the spar on the center section and run behind the spar on the outer panels with no factory provision to relocate them . I will need to drill a hole in the spar under the aluminum blades to pass the wires through so they will come through in the same areas. I will add pics this afternoon.
