Ok, things are moving along nice, the gear set is here, thank you Mike and the USPS for a quick service, as you can see they will do just fine, very little mods to be done ( ahhh, the fun of building again, happy, happy ) once it is all done it will stand about 1 1/2 inches taller than the stock build ones
The air tanks that came with the gear set are fine but, I don't think I will need that much air, I have a smaller air tank for the retracts and an even smaller for the brakes, I will place them above the boat as there is plenty of open space in there and since they are very light their weight won't affect the CG that much if any, the space where the air tank is supposed to go will be used for the ECU, the steering servo will be in the same location, just a bit back to clear the nose wheel, all the extra weight that is been added is been added forward of the CG and that ia a good thing.
