I agree with ahicks about running the low needle a little more rich . I would also add that until the engine breaks in more you probably will have some mid range roughness and some throttle transition issues. Get a reliable idle and reasonable transition and just fly it to get it a bit more broken in . When the rings seat and the friction reduces you will be able to get better needle response and better performance
