Originally Posted by
RustyUs
Diff pinion gear shim = 3Racing (#3RAC-SW08) Stainless Steel 10mm Shim Spacer 0.1,0.2,0.3mm Thickness
Differential shim = Team Associated #92079 15mm Differential Shims
perfect thank you for the part numbers!
the bearings are brand new, changed them 2 weeks ago when I replaced the first set of gears. The pinion gear comes with a new shaft when you order it, I only ran 2 batteries through before the second set went.
