Originally Posted by
sewergod
Need some help! Problems updating firmware. I've got three of these CTUs (new). Upgraded two of them perfectly, the third will not boot up with SD card installed. Removed card, powered off, then power back on, boots up normally and Jeti CB 200Device explorer recognizes CTU. Is there another procedure for updating the firmware? Suggestions? Thanks
The last time I upgraded several CTU’s the firmware file was erased from the micro SD card after upgrade process. Re copy the firmware file over to the SD card and retry...
David
