Funtana s90 Fuel Tank w/DLE20
So I just picked up a brand new Funtana s90 (never been opened still fresh in its packaging). I got the air frame assembled and will be installing a DLE20 on the plane. I also got an Extreme Flight Flowmaster Gas Tank 17oz. Because of the location of the throttle and choke on the DLE20 (I do plan on having the choke on a servo) I'd like to see pictures of this plane with the DLE20 and how you have your gas tank setup (in front or behind wing tube?), throttle and choke control setup. I'd also like to know if you used the included engine mounts with the DLE20 or did you have to use a different engine mount? Any help would be appreciated. Thank you.
