I need advice on a good way to remove a Fox 40 crankshaft collar. I suppose I will have to use heat but I did not want to do that if I didn't need to to prevent stressing the front bearing. Also, how to pry that off? It is quite small so a pulley puller won't have enough to grip it. Sorry the picture is a bit fuzzy.
