https://www.nitrorcx.com/28h-u842-falcon-white-4g.html
The UDI RC U842 FALCON Quadcopter is loaded with features, perfect for the beginner or seasoned pilot. The U842 Falcon is equipped with an 720p HD resolution camera allowing you to make a record of your aerial adventures in HD quality. The quad-rotor design is designed with detachable propellers guards to protect against light collisions allowing you to continue flight uninteruppted. To pilot the U842 Faclon, a 4-channel 2.4 GHz handheld transmitter comes in the box and is pre-bound to the aircraft, making this bundle ready-to-fly. The Falcon has the ability to set speed modes for flight calibration. A high speed mode for more advanced pilots or to compensate for windier conditions and a low speed mode ideal for beginners. The falcon is also equipped with a 1000mAh Lithium flight battery, a USB battery charger, a 4GB microSD card, a USB card reader, and a screwdriver. The Falcon comes in two choices of colors, black and white.
Features:
Integrated 720p camera with video recording capability as well as a single shot photo mode
Perform flips and 360-degree rolls with the press of a button
Includes 2.4 GHz transmitter (radio controller)
Included battery lasts up to 8 minutes and features a USB charger
6-axis gyroscope provides flight stability
LED indicator lights to aid in orientation, especially at night
Slot-in battery design to make battery swaps fast and easy
High and low speed modes to accommodate different skill levels and varying amounts of wind resistance
Low voltage alarm produces audible tone at the transmitter warning you to land the aircraft as soon as possible
Specifications:
Length: 19.3 Inches
Width: 19.3 Inches
Height: 4.8 Inches
486 x 486 x 122 mm
Weight: 355grams
Photography Modes: Single shoot
Video Recording Modes: 1280 x 720p
Max Bitrate Of Video Storage: 30 Mbps
Supported File Formats: FAT32
Photo: JPEG
Video: AVI
Supported SD Card Types: Micro SD
Max capacity: 32 GB
Operating Frequency: 2.4 GHz
Transmitting Distance (Outdoor And Unobstructed): 80 m
EIRP:
[email protected]
Operating Temperature Range: -10 ~ 40 C
Package Contents:
1x U842 Falcon
1x 2.4ghz Transmitter
8x Total Propellers
3x Total Batteries
1x USB Charger
1x English User Manual
Required to Fly:
Battery: 4 1.5V AA Alkaline batteries
