Hello
I have made a new prop hub based on my check of timing on My new engine.
Have used Proxxon dividing attachment 24264 to drill Hole for each magnet.
My goal was to have timing each cylinder within 1 degree and i almost made it, it is now
cylinder 1 30 degree, cylinder 2 30,5 degree and cylinder 3 31,5 degree.
I did borrow a lathe and bought dividing attachment and i am happy with the result with this cheap tools used.
Have started the engine and made brake in run and started to lean it but have not been possible
to have same temp on all cylinder and have turned engine during brake in to lean cylinder 2 and 3.
Next step is to buy intake kit from Morris mini motor .
The goal with all this is to have a engine that don't brake down and you can use for long time with normal maintenance.
Are now traveling and working and have to wait to be back at home for more test of engine.
