Originally Posted by
NL Flyer
Ok. Perfect.
Anything I should keep in mind?
I will also be adding mounting blocks for tail dragged set up. Where did you position your mounts for the main landing gear?
also, my wing has been modified for ailerons. I’ve cut the dihedral in half. Currently has strip ailerons. I would like to go to barn door and flaps. I know it doesn’t need flaps. I am doing it as an experiment and for the hell of it.
Any suggestions?
Rule of thumb I have always used with good results to convert tricycle to tail dragger is to block the fuse up into a level position and locate the mounting blocks so that the axles are directly under the leading edge of the wing.
