Originally Posted by
rampage-1
Hi John
Your picture looks just like the way mine came in. And you are correct, you have to be very careful when you you try to iron it down.I have ironed the whole plane twice so far. My ailerons were the big problem they did not have the correct movement, only about half from what the manual gives for low and high rate. The pin hinges were factory set to far in. I ended up cutting them off and redrilling for new Robart to correct the problem.I had to add support to the frame in a few areas, especially in the rear where the battery's are located. I am using a DLE111 so I need weight in the rear battery box. The struts had to be re-built. I ended up lining the interior wall with thin mylar sheeting so the springs would not rub. Also I installed a steel tube over the screws that hold the top struts in. The threads started cutting into the top strut bracket. I also added a spacer to kept the struts centered in place at the top.Next I added some wood to make the strut bracket a little stronger. I also added screws around the side windows a few guys have had them blow off due to the glue job is very poor. They do not sell doors or windows in the spare parts area.Also I replaced the tail wheel. The tire that came with the kit was way to soft. I set the CG at 10
inches
What is the trick to get the shocks apart? I can see the shaft unscrewed from the plunger but was not able to get it to undo, the whole plunger keeps turning in the cylinder.
