RCU Forums - View Single Post - TF FW190 GIANT ARF
Old 01-23-2019, 10:28 AM
  #4624
CaptRKO
CaptRKO's Avatar
Originally Posted by Hot Rod Todd
Many have mounted the DLE-55RA. The dimensions are almost the same as the regular 55. 55RA is 171mm mount to prop hub, 55 is 170mm. You need the same number of spacer plates to get to 184mm.
Yup I checked online and your measurements are correct ,thank you!
However my standoffs are 75mm long (came with engine NIB) so for some reason I have longer standoffs than stock. Weird?
