A couple little tricks I like to use to get the throttle a little bit more linear is to make a longer throttle arm, use a throttle curve on the TX and max opening about 85%. Usually when running this type of setup my throttle ATV is up around 120% to 130% to get the 85% throttle opening. I have used this method on 50cc to 200cc engines.
