Originally Posted by
Skyhawk940
Just my thoughts about servos. Digital servos are more precise and have higher holding power. I know my real old analog servos would get dirty on the var. resisters and not be so dependable. If you don't need the digitals, I would still swap out the servos with new analogs. Sitting for 7 or 8 years is quite a while.
Thanks for clarifying -- and good advice. I was a little worried, reading into your comment and seeing all of the new SBUS, CPPM, I-BUS stuff on the market during my initial research, that I feared that I was also facing at a wholesale servo swap-out on top of receivers and Rx battery packs. I've done a lot more research now and see that the good ol' fashioned PWM servo interface is still around and available in receivers that work with the new radios.
