Originally Posted by
carlgrover
The Fox .45 has a larger frame size than the .40. Put them next to each other and it's obvious.
carl
Fox made a B case .40 as well as the C case (Compact) .40.
AFAIK the B case .40 never came ringed, but the .45 is ringed. I remember reading the .40 B case came in ferrous lapped construction and ABC, but I’ve never seen an ABC version. The flat flange mounted carb is a B case and the square bore necked carb came on the compact .40s. IIRC the B .40 was about 1,000rpm faster than the compact .40 on the same prop.
