Originally Posted by
speedracerntrixie
Would you be able to drill a hole in the lead chunk and rig up some sort of slide hammer? Depending on the adhesive used a little heat may help as well. The fuselage and paint shouldn’t have any issues up to about 120 degrees but if epoxy was used to secure the weight 120 will soften it some.
Cannot really tell if it is fiberglass resin or just epoxy. I will keep your input down to try when I tackle the project.
