2 questions;
1. I am mounting a demon cortex (not pro) in 1/5 scale gas prop plane. I understand having the gyro facing forward but the gyro will be mounted upside down in the fuse. Must I reprogram the mounting position or does face up or face down not make a difference and this is recognized in setup ?
2. If I understand the setup instructions correctly I can do the setup for the gyro but leave the gyro turned off for the first trim flight. Once I get the trim flight and control throws done, for the 2nd flight (after checking for correct directional gyro control) I could turn the gyro on in flight and the gyro will recognize the new correctly set trims and throws from the startup initialization prior to second flight?
Roy
