Originally Posted by
Auburn02
Yes, that's the newest engine from KT in that size/range.
And as you also said, you'll need a 9.9V LiFe battery and of course your receiver, but other than that it's all there.
Thank you! That helps a lot. In reading about rc jet engines, there are new models by all manufactures that have simplified the overall process to connect fuel, leads, etc to get ready for start / run. I guess the older models required several fuel connections and now the new models have a single fuel connection, as example. Would you say this K85G2 is the older style (more complex to setup) or the newer style (more simple)?
